farmall oil pressure help
wegman in mn
06-29-2007 20:03:19
my farmall h when started will hold steady at 70 lbs oil pressure, then when warmed up will fall down to 50 lbs. does the head need redone?
thanks to all.
Andy Motteberg
06-30-2007 13:28:41
 Re: farmall oil pressure help in reply to wegman in mn, 06-29-2007 20:03:19
That's fine.
old
06-29-2007 21:52:38
Shoot with those numbers what are you complaneing about. With a tractor that old 20 PSI is very good
K.B.-826
06-29-2007 20:06:40
What does the head have to do with oil pressure? Worn bearings cause low oil pressure. 50 lbs. is quite good for a old H. How much do you have with the enigne fully warmed up and at an idle?
