distallite engine
elvin c frank
06-29-2007 21:01:29
what does having a distallite engine mean, is that good bad or ugly? are the parts harder or more expensive to get???
alex ahlbrecht
06-29-2007 21:32:25
 Re: distallite engine in reply to elvin c frank, 06-29-2007 21:01:29
do you have any pictures of it? if you posted some i am sure someone could help you .
RN
06-29-2007 21:15:52
Distillate? Means originally ran on 'distillate' fuel- think kerosene and you'll be close. Some parts harder to find- radiator shutters, small fuel tanks, heat shields. Engine basicly same as gas engine, most can run on straight gas with minimal adjustment- they were meant to be started on gasoline and switch to distilate when warm. Some added collector value if still able to run kerosene/TVO. RN.
elvin c frank
06-29-2007 21:20:56
 Re: distallite engine in reply to RN, 06-29-2007 21:15:52
I don't believe that's what it is,it doesn't have any extra tanks and no hole in the hood as suggested in the other reply, I appreciate all the information being provided, this is a great source of information
John M
06-30-2007 07:31:26
 Re: distallite engine in reply to elvin c frank, 06-29-2007 21:20:56
Yes, thats exactly what it "is". Cahnces are the peicesz were removed at some point. Know why you need to know will help expalin to you better.
RN
06-29-2007 22:10:37
Probably converted like many in late 50s on to straight gasoline. Distillate advantage was use of cheap fuel, diesel and jets started using the same light oil fractions from refineries and cost went up. RN
