check out this m with duels!!!! only 750 in TX!!!
jonnny2006
06-30-2007 00:13:00
third party image
i wish i was closer!
randy hall
06-30-2007 20:27:13
 Re: check out this m with duels!!!! only 750 in TX!!! in reply to jonnny2006, 06-30-2007 00:13:00
looks like the junk that sam adams tries to pawn off as a tractor.
georgeky
06-30-2007 15:57:03
Jonnny, I put a picture of my 53 Super C with duels and mowing pasture. It is fuzzy. I don't have a scanner and had to take picture of the picture. I am posting one more of it in stuck and toubled.
jonnny2006
06-30-2007 13:51:38
I thimk it still looks cool. now looking at wile im awake i can see that it is just too wheels. so what...it would be cool to cruise around as it looks cool. I bet if you had the optional 100 inch tred axles you could get 3 pairs on each side! then take and put a set of duals on the out side set amd make it a 8 wheel deal! I"d like to see that! But 750 for the whole tractor seams pretty cheap UNLESS it dosent run and is stuck.
Andy Motteberg
06-30-2007 13:14:30
They are just a double set of IH wheels, not optional duals. $750 is plenty.
Curt from Minnesota
06-30-2007 16:00:25
 Re: check out this m with duels!!!! only 750 in TX!!! in reply to Andy Motteberg, 06-30-2007 13:14:30
750 to 1500 is what they go for unrestored but good running condition in MN and East SD. At least in the sales and adds I seen. To bad its in TX. You could really push some snow with it. When you see things like that large blade, and dual, you have to wonder how worn and fatigued are the gears and shafts. my guess is that it was not used for snow removal.
Curt
RustyFarmall
06-30-2007 05:58:23
Looks like nothing more than an M with 2 sets of wheels and tires. If you slide the first tire/rim/center combination all the way in on the axle, there is room to mount a second set. The factory dual option used what basically amounted to 2 rims on one center, and a pair of quite narrow tires mounted on those rims.
