Spark Plug Thread Spec
Doug Kieta
06-30-2007 10:12:20
I want to purchase a compression tester for my '49 SA and my '51 H. The Champion spark plug book shows that the thread on their recommended plug, RD18Y, is 18mm. I find that hard to believe because metric threads were not utilized back in those years. The only tester I can find has 14mm and 18mm threads. I want the screw-in type fo tester so that I can leave it in the cylinder when I crank the engine.
Does anybody have an H under restoration? If so, would you mind checking the plug thread to see if it really is 18mm rather than an SAE thread?
Thanks for the help.
CGtractor
06-30-2007 14:16:48
 Re: Spark Plug Thread Spec in reply to Doug Kieta, 06-30-2007 10:12:20
It is 18 mm
EL Toro
06-30-2007 10:25:44
They had 14mm back in the 1940's. !949 & 1950 Fords both used H10 Champion plugs and I use the same plug in old Toro mower today. Hal
