Farmall H main drive housing removal
SLH IN MO
06-30-2007 10:13:58
Can anyone tell me can the main drive shaft housing bearing assembly be removed on a farmall h .without removing the transmission top or belt pully housing.THANKS for any help.
Roger46
06-30-2007 16:51:47
 Re: Farmall H main drive housing removal in reply to SLH IN MO, 06-30-2007 10:13:58
I removed mine on my Super H some years back by removing the hydraulic belly pump unit and working from under the tractor. I did remove the belt pulley so I could see what was going on when I reassembled it as it was easier to put it back together when you can see how things are going together. It is kind of like working on your car as you need to lay on your back for the whole operation. The hardest part for me was getting the drive coupling apart. Roger
