560/M Center Castings?
LittleMackinawFarmall
06-30-2007 21:32:47
Okay dumb question I know the M has 2 slots the 560 has 1 will the center castings fit on the M from a 560? I bought a M site unseen yeah not recomended but anyway bought it mostly for parts but the motor dyno'd at 54hp so we are gonna pull in but the tires are junk...so now I had a thought while sitting here maybe the 560 tires could go in it if i could use the casting dunno....
BF8690
07-02-2007 15:50:54
 Re: 560/M Center Castings? in reply to LittleMackinawFarmall, 06-30-2007 21:32:47
The axels are the same diameter. You have to use the entire cast wheel assembly off of the 560.
Sagebrusher
07-01-2007 11:58:09
I'm a bit confused about where you are headed with the center casting swap and tires, rims, etc.
For what it is worth, I bought a set of Power Adjust wheels and rims with excellent condition chloride filled tires last winter that reportedly were from a 560. They had only the single key but were for a 2.75 inch axle just like my M. They bolted right up to the M.
The hardest it works anymore is with an eight foot blade and a nine foot disc. If the single key way held up to the 560's hp it should continue to do so on the old M.
D Slater
07-01-2007 07:31:04
Sure can,the 560 wheels are probably cast # 363014 R4 or R5. May interest you to know that in 1956 IH released a service package with that type wheel and rims for use on M,SM.SMTA and 400 with serial # 501 to 5180 tractors. Reason given to meet sales demand for a wheel with improved hub to axle mounting and to provide a easier means of tread adjustment by use of double beaded rim construction.
