M thermostat housing
Mifsud
07-01-2007 11:08:18
Put new thermostat in my m. For some reason will not let the thermostat sit down in the housing to make a good seal. Keep on leaking when reinstalled. Anyone have this problem before. Iam about ready to pull it out and run without one. Any thoughts on that.
Bob Kerr
07-01-2007 15:12:43
 Re: M thermostat housing in reply to Mifsud, 07-01-2007 11:08:18
Just did one last week and had the same problem Thomas talked about, cleaned the inner hole of rust and it was ok.
Thomas D Windsor
07-01-2007 12:34:23
I am wondering if there is rust in the top section that will not allow the thermostat to slide up into the housing? I had the problem on an H, cleaned it and then it was good.
tw
