On the 51 M's Should the serial number match?
jonnny2006
07-01-2007 19:01:37
on my 51 m the serial numbers do not match. interestly enough the serial number on the engine soes not match the number on the chasis.....Are the newer M's like the super h's where i.h. dint match serial numbers. Was ther a ryme or reason to the numbers they did use? as i posted my chasis serial number and someone on here guessed the engine serial number within a few numbers. Was there a set way they did it or did they just grab the next one off the rack?
John M
07-02-2007 03:19:01
 Re: On the 51 M's Should the serial number match? in reply to jonnny2006, 07-01-2007 19:01:37
No, they wont.Imagine this. I line with tractors and a line with engines.1st 200 tractors and engine are the same type, then low and behold an orchard or an industrial or a Standard comes through the line. The guy doing the stamping on the engine has no idea that it has changed, and the guy who is stamping the chassis plates does, the chahsisis plates starts with where he left off from the last time he stamped a standard, orchard or industrial, but the guy stamping the engine keeps right on going with the next number.Understand?
Andy Motteberg
07-01-2007 22:05:42
The number should match, or its not the original engine. The serial number on the tag on my H is FBH-133801 and the number on the engine is FBH-88099 and the casting codes on the engine and clutch do not match. If the engine & tag numbers match like they do on lots of our other tractors, it is the correct engine.
City-Boy McCoy
07-02-2007 09:11:33
 Re: On the 51 M's Should the serial number match? in reply to Andy Motteberg, 07-01-2007 22:05:42
Andy, are you sure? I don't think the numbers would/should match on an M that new. I know they don't on my Super A's and my Super H. mike
georgeky
07-01-2007 20:42:11
My 1950 has 10,000 difference in engine number. I know it has the original engine.
D Slater
07-02-2007 05:29:25
 Re: On the 51 M's Should the serial number match? in reply to georgeky, 07-01-2007 20:42:11
George, is your M below serial # 240000? most seem to jump to 11000 differance around 240000 or above. Looked at some notes I keep after answering jonnny and think his 51 would be 12000 differance. M parts book says no attempt was made to match chassis and engine serial numbers. On at least the last 5 to 6 years of M production it seems some kind of system was used because most of those M have a engine serial # exactly so many thousand below tractor serial #, more than can be a coinidence. The newer a M tractor the more differance between numbers. Example of actual tractor 286713 X1 engine 273713 X1 13000 differance. Most if not all original H tractors match.
georgeky
07-02-2007 06:17:06
 Re: On the 51 M's Should the serial number match? in reply to D Slater, 07-02-2007 05:29:25
D Slater. My 50 model is 223*** . The engine number is exactly 9997 lower than the tractor. My uncle bought this tractor new and it does have the original engine in it. My other M is at the other place and I can't find my notebook with the numbers right now.
D Slater
07-02-2007 06:23:07
 Re: On the 51 M's Should the serial number match? in reply to georgeky, 07-02-2007 06:17:06
Maybe I just ben lucky on about all M from 49 model up I have looked at were exactly so many thousands differance. Thanks.
georgeky
07-02-2007 06:32:30
 Re: On the 51 M's Should the serial number match? in reply to D Slater, 07-02-2007 06:23:07
I don't know. I never really paid any attention to them until folks here started talking about it. My 50 has never been out of the family.so I am sure it has the engine it came with. My uncle bought it new, then sold it to my dad, and he gave it to me about 3 years ago. It was overhauled in the late 60's and over bore IH Fire crater pistons installed then. In 1990 dad put new rings, bearings and rebuilt the head. She is still going strong.
D Slater
07-02-2007 09:57:54
 Re: On the 51 M's Should the serial number match? in reply to georgeky, 07-02-2007 06:32:30
I believe you that its the correct engine, wasn't disputing that. 50 M I have is 232719 X1 engine # 222719 X1. others I owned at one time 243658 X1 engine 232658 X1 , 238818 X1, engine 228818 X1. 51 model 274061 X1B engine 262061 X1B, 276739 X1 engine 264739 X1. 49 model 200252 X1 engine 192252 X1. The example I gave in post above was a 52 model, but some listings call that a 51 model. Not saying you missread your # but about ever 50 model M I have checked and I find the last 3 numbers don't match, I think thats not working like the rest, so I check agiain and find out I missread one of the numbers in all but a few tractors. Not claiming any of this is foolproof, just interesting stuff to notice.
georgeky
07-02-2007 14:39:01
 Re: On the 51 M's Should the serial number match? in reply to D Slater, 07-02-2007 09:57:54
D Slater, I went and scraped the paint off and guess what. It is 10,000 instead of 9997 off. The last 3 wasn't stamped real good and looked like a 6 until I scarped the paint off.
D Slater
07-01-2007 19:34:49
This is not 100% correct all the time but if you have a mid year 51 gas M the serial # is probably exactly 12000 less on engine than chassis serial #. If early 51 11000 less, late 13000 less. Maybe 10000 less if real early 51. How did it work out?
jonnny2006
07-02-2007 08:28:03
 Re: On the 51 M's Should the serial number match? in reply to D Slater, 07-01-2007 19:34:49
my 51 M has the same last 3 numbers they are 650 i thought it was ,more then just lucky that they had the same last 3 numbers.
CNKS
07-01-2007 19:05:31
The only letter series tractors where the serials absolutely match are the A and B, and then only through 201000. I have read that the H numbers match, I have not checked mine. The M numbers do not match. Close, I do not know.
georgeky
07-01-2007 20:46:20
 Re: On the 51 M's Should the serial number match? in reply to CNKS, 07-01-2007 19:05:31
CNKS, I don't know if all H numbers match or not, but the numbers on my 44 H do match. Niether of my M's match.
