IH 2504?? injection pump timing
moline
07-01-2007 19:29:59
Hi,A friend of mine picked up an IH industrial tractor loader backhoe.The serial number plate has been sanded and I cant find the model.By the stamped serial number I think it is a 2504.It is a 4 cylinder indirect injected engine with a roosa master pump.The previous owner had removed the pump and the engine was not set on #1.I found a pointer on the timing cover and marks on the balancer.Does anyone know where the timing should be when the marks in the window of the pump line up.I have went through several manuals and am coming up with everything from 0 to 5 degrees BTDC.Any help would be appreciated.Thanks,Moline
Larry in Mol
07-01-2007 20:17:57
 Re: IH 2504?? injection pump timing in reply to moline, 07-01-2007 19:29:59
Bring the #1 cyl to TDC. Keep going till the timing pointer lines up with the 2 degree ATDC mark. If the lines in the window do not line up, loosen the 3 cap screws in the pump drive hub and turn untill the lines are even again. LE
I&T IH-201 Manual.
