IH/Rockford Clutch
SCOTT300IA
07-02-2007 05:16:22
I am replacing the drive clutch in my 1955 Farmall 300. Tractor has a TA. When I look clutches up there are two styles- IH & Rockford. How do you tell which one is in your tractor?
Kevin Meier
07-02-2007 19:06:41
 Re: IH/Rockford Clutch in reply to SCOTT300IA, 07-02-2007 05:16:22
I have an entire clutch kit available or the pressure plate with woven, 4 pad or 6 pad disc. Email me if interested.
Janicholson
07-02-2007 06:19:19
JIt will not matter, The Rockford is in most cases the only style available. Though different looking, they are operationally the same. Rockford Pressure plates have been considered a bit tougher, but not much in the real world. JimN
PORKY B.
07-02-2007 05:38:53
Check the serial number plate,code J means Rockford clutch.
