IH 166 D ?
dej(jed)
07-02-2007 05:18:13
I bought an IH 340 diesel dozer. The engine looks just like the 236D & 282D. Is it an IH or a continental engine? What tractor used that engine?
Thanks..... ...
Haas
07-02-2007 11:57:24
 Re: IH 166 D ? in reply to dej(jed), 07-02-2007 05:18:13
The TD-340 uses an IH D-166 engine. It's the same engine as in the IH 340 diesel wheel tractor. It may be in some other tractors as well. A lot of other chassis components of the 340 dozer are common to the 340 wheel tractor as well.
FromJB2
07-02-2007 09:30:13
Hi is it a direct start Diesel or require glow plugs?
JimB
ellson
07-02-2007 16:55:55
 Re: IH 166 D ? in reply to FromJB2, 07-02-2007 09:30:13
Has glow plugs
georgeky
07-02-2007 06:23:44
It is an IH engine. The only IH tractor to use a Continental was the 350 in rowcrop and utility versions. And then it was a GD-193
