806 oil light when clutch is depressed
IH Nate
07-02-2007 05:45:38
I have a 67" 806 diesel, and I just adjusted the clutch, trans brake and dump valve the way that the tractor vet said to. The oil light comes on every time the clutch is depressed/or the dump valve kicks in. Wondering if this is normal and if not how it is fixed.
MN Scott
07-02-2007 06:01:57
 Re: 806 oil light when clutch is depressed in reply to IH Nate, 07-02-2007 05:45:38
The light is supposed to come on when the clutch is depressed. It means you have the adjustments right on or at least close.
