SMD Serial #
Southern4020
07-02-2007 17:50:02
I just called about a tractor I want to buy and the guy said the Model # is SMD Serial # F42132J and that it was a gas tractor.Am I correct in that the SMD is Super M diesel But the F is a gas serial number.
Marv
07-02-2007 19:48:01
 Re: SMD Serial # in reply to Southern4020, 07-02-2007 17:50:02
CNKS, I read your post and your comments make lots of sense. However, My SMD serial number is definitely an E instead of a F. Does this make it more valuable?? Ha Ha.
I agree that the first line is either SM or SMD on the super series. The second line should start with a F or an L depending on the manufacturing location. Marv
D Slater
07-02-2007 19:05:58
If the serial plate is still readable and its a SMD serial plate. Above the F 42132 J on plate would be SMD with D stamped in. F just showes it came from Farmall works instead of Louisville. To the best of my knowleage no diesel SM tractors were assembled at Louisville. No information you give rules it out from being a SMD.
Marv
07-02-2007 18:52:14
I have a 1953 SM gas and a 1953 SMD. Listed below are the serial numbers.
For the gas:
SM
F47872J
For the Diesel:
SMD
E43380J
Hope this helps. Marv
CNKS
07-02-2007 19:03:43
 Re: SMD Serial # in reply to Marv, 07-02-2007 18:52:14
The E in the second one is really an F.
CNKS
07-02-2007 18:47:58
The 4 cylinder IH diesel engines start on gas and then switch to diesel -- the seller does not know what he has, so beware. The SMD is the correct serial prefix for a Super MD. The F probably means it was built at the Farmall plant, some Super M's were built at the Louisville plant and have an L prefix. But, I was under the impression that the those built at the Farmall plant did not have the letter F, but that the Louisville ones had the L. Possibly the diesel engine was replaced with the Super M gas engine.
CNKS
07-02-2007 18:52:27
 Re: SMD Serial # in reply to CNKS, 07-02-2007 18:47:58
The gasoline engine suffix, not prefix, is X1, the X1 is to distinguish it from distillate and kerosene engines which were still available at that time; the diesel ones do not have a suffix to identify them as diesel as that engine is self explanatory.
