changing fuel filter 424D
Gary in Mozarks
07-03-2007 18:11:36
Is there a trick to getting fuel back up to the pump after changing the fuel filter? I have fuel comming out the top fitting of the filter bracket on the right side of the engine, but I can't get fuel to come out the other end of the line where it goes into the pump on the left side of the engine. I realize there is a bleeder on the pump but I can't even get it to the pump. thanks
Bob
07-03-2007 23:13:06
 Re: changing fuel filter 424D in reply to Gary in Mozarks, 07-03-2007 18:11:36
All's I've ever done is to fill the new filter with clean fuel, then install it, and crank the engine 'til the fuel comes out the bleed plug on the IP.
