kill cable for 1940 A
Brad in WA
07-03-2007 19:19:44
Anyone have a pic of a kill cable and switch for the mag on the 1940 Farmall A. I need one if you know where I can get one please let me know.
Thanks in advance
randy hall
07-04-2007 20:35:06
 Re: kill cable for 1940 A in reply to Brad in WA, 07-03-2007 19:19:44
justin weber has them. they say stop on the knob.
justin w
07-05-2007 22:28:32
 Re: kill cable for 1940 A in reply to randy hall, 07-04-2007 20:35:06
they actually just have an S on the knob..
dave guest
07-04-2007 20:04:59
Go to motorcycle shop and buy a kill plug with stretch cord to attach to person. Need to know if you want to make or break circuit to stop. Very inexpensive.
Wardner
07-03-2007 19:51:08
I recall that someone said that OEM Tractor makes the brass pull knob and cable. I'll send you a picture of mine topmorrow. It's on a 1940 H. Length is probably different.
Brad in WA
07-03-2007 20:52:49
 Re: kill cable for 1940 A in reply to Wardner, 07-03-2007 19:51:08
Thanks. I guess not many had the cable kill.
Wardner
07-03-2007 22:32:33
 Re: kill cable for 1940 A in reply to Brad in WA, 07-03-2007 20:52:49
They were a liability problem. If you let go too early, the engine would "re-start" as it was spring loaded. I imagine a few people were injured or killed.
And like all wire inside a cable, they would seize if not maintained. Most were retrofitted with a grounding switch.
Brad in WA
07-04-2007 09:35:32
 Re: kill cable for 1940 A in reply to Wardner, 07-03-2007 22:32:33
That is true. with no cable, by hand if you don't hold it back it will restart. I still want to find a cable and switch.
