Wiring harness Letter series
GordoSD
07-03-2007 21:13:52
I have the BobM diagrams for wiring. But I would like to have color coding. Anyone have that? Also, what is the source for the original outer sheathing for the harness, the braided covering? Is it available in bulk?
Gordo
the tractor vet
07-04-2007 17:21:06
 Re: Wiring harness Letter series in reply to GordoSD, 07-03-2007 21:13:52
The color is from the alt or gen. off the arm. is Blue and the fiel wire is yellow and the ing. wire is black . If i am maken up a wire harness for and alt. i run a 8 ga. in blue to the amp gauge the yellow to trigger the alt. is in a 14 ga. and the way i do up a push me pull me switch for the ing. is i use a Cv relay to trigger the alt . and use the ing. as the trigger wire for the cv relay . The ing. switch to coil is in black and is 14 ga. from the amp gauge to starter pos post is a 8 ga in red , you can get away with a 10 ga. instead of the 8 but i like to go heavier . Lites are either in a brown or a purple in a 14 ga. to 12 ga. As for the sheild yes it is av. in bulk and i get it from Terminal Suppy out of Cleveland O. also get heavy duty no insulated ends from them and use black heat shrink after crimping , this makes for a more Factory look then blue and yellow plastic showen .
GordoSD
07-05-2007 08:50:25
 Re: Wiring harness Letter series in reply to the tractor vet, 07-04-2007 17:21:06
Thanks vet. I have to make up three harnesses so I'll buy in bulk!
Gordo
Andy Motteberg
07-03-2007 21:16:34
Go to this site.
Andy.
