Farmall F-14 magneto
H fanatic
07-03-2007 22:12:11
Hello,
I have a 1938 farmall F-14 with a IHC F-4 magneto and I was wondering how often it should spark in relation to the impulse? Right now it makes the #1 cylinder spark plug spark about every 4 clicks of the impulse. Sometimes every 2 clicks. Is that good or should it spark every time the impulse clicks? Any information would be greatly appricated.
Thanks,
Nick
John M
07-04-2007 14:32:17
 Re: Farmall F-14 magneto in reply to H fanatic, 07-03-2007 22:12:11
It will spark each time the impulse clicks for the corresponding plug, 4 clicks, 4 plugs but only twice per revolution could be a sticking impulse
Bob Kerr
07-03-2007 22:18:08
I think it should spark on #1 cyl once in 4 clicks. The other 3 clicks it is sparking the other cyls. If it isn't clicking it won't start unless pulled. Be sure to lube the impulse coupler good, might want to flush it out with kero and then oil it good. the bearings though just a few drops in those.
