Carb Paint
SteveW
07-04-2007 15:34:01
This weeks project is to paint my carb Whats the best paint could be used for shiney finish.And it seems that my farmall has so much power when the carb is turned up and the dirt is a spinning that my carb is very frosty of coarse but it has a milky residue were the frost was that stains the black finish is there anything i can do for this
steve
Tom Windsor
07-04-2007 20:09:31
 Re: Carb Paint in reply to SteveW, 07-04-2007 15:34:01
third party image
I jut painted this H Carb today with Rustolium paint. We will see what gas does to it.
John in CT
07-04-2007 18:18:13
The only paint that I think will hold up because of alcohol they put in the gas where I live (CT) would be Dupont 615+620 primer and Imron topcoat. I haven't tried it with the new gas yet but I have put dried Imron paint into brake fluid as a test and it held up ok.
Andy Motteberg
07-04-2007 17:20:59
Clean the carburetor real good inside and out and put in a kit. Make sure the carburetor is adjusted. Use high quality gaskets, or the fuel may leak. Clean out the fuel screen in the carb. You should bead blast the carb, and paint it IH red, there is no need for primer or coatings.
CNKS
07-04-2007 17:16:51
The carb is supposed to be red. Turned up carb? More power? They only go so far, then they are too rich, leading to carbon deposits, etc. Adjust it to specs.
