sluggish govenors on an H
Charlie M
07-04-2007 15:34:57
The govenor on my H has gotten very sluggish. It either doesn't open up under a load or if it does it takes time. I had the cover off and I don't find anything binding. Could it be a problem with the thottle linkage and not the govenors? Any thoughts?
Slappy
07-04-2007 18:08:21
 Re: sluggish govenors on an H in reply to Charlie M, 07-04-2007 15:34:57
Check the linkage first - it's easy and the proceedure is in the owners manual. If you are certain that the linkage is OK and that nothing is binding, the two most likely causes are the spring (a new spring is the only fix) or the weight-pin-carrier assembly.
To check the latter, look to be sure that the pins are tight in the carrier (the weights rotate on the pins, the pins do not move in the carrier). If the pins are tight then it's a good bet that the pin holes in the weights are worn into egg shapes. You'll be amazed at what a big affect you get from only a little wear here.
You can still get pins and weights from the dealer, but you'll need a used or NOS part if the carrier is worn out. Although if the wear isn't too bad you might have a shop that can bore and bush the carrier.
Jim in polk co
07-04-2007 18:07:12
Go to your IH dealer, they used to have a kit to fix an H govenor. If he dowsn't have a kit tell him you want new pins that the weights swing on. Its been a while since I"ve done mine but there is also a washer in there that will wear more on one side that the other. Either get a new washer or turn the old one half away around. Make sure the weights will swing free on the new pins. When I did this on my H it made a big difference.
Bob Kerr
07-04-2007 16:01:17
Mine was acting up a bit until I tightened up the loose manifold. I had to readjust the carb afterwards.
