756 IHC PTO VALVE L;EAKING
lenray
07-05-2007 07:52:37
Hello TV--OTHERS I mentioned awhile ago about the leaking where I engage the PTO back behind the seat.
I have taken the big nut off but not sure how to pull the valve out. Does it screw out or just give it a good pull. It seems to be in there pretty good--not sure how much pressure to apply to get it out.
thanks have the test kit coming from IHC to plug into the port to set the pressure one the seal is replaced.
the tractor vet
07-05-2007 12:47:44
 Re: 756 IHC PTO VALVE L;EAKING in reply to lenray, 07-05-2007 07:52:37
The valve for the PTO come out the bottom not the top .
