SA 3 point
mark
07-05-2007 14:54:07
I think I am going to mount a 3 point on my Super A. Have any of you done this and if so, what kind of lower hitch arms did you use?
Looking at things, I think the hitch arms will work with the rear cultivator brackets on the bull gear housings. Slide the rear gang out, replace with hitch pins and mount the arms on them. I can then use my 3 point rear culitvator to cover my tracks....and also use other implements like my finish mower as well. I have no idea how much lift capacity the SA has....but surely it will pick up the finish mower. This is just for handiness and not heavy duty work...have a big tractor for that. Just seeking ideas. Thanks.
Pete7
07-05-2007 18:05:51
 Re: SA 3 point in reply to mark, 07-05-2007 14:54:07
Hi Mark...Awhile back I put a 3 pt on my Super A. I bought the setup that Worksaver sells. It works but isn't great. You can lift a max of 600 lb with the Super A hydraulics, but that is more than I would feel safe doing. I set up my 3 pt so that I could keep the complete IH drawbar attached while the 3pt is also on the tractor. I mostly use my 3pt for a Bush Hog and for a one row 3 pt rear cultivator. Setup this way, I can use the drawbar for my trailer plow, drag discs, harrow, etc and then, just hook up the mower or rear cultivators to the 3 pt, without the hassle of having to take the drawbar off or put the 3 pt on. (I just keep the front cultivators mounted on the tractor the whole season.) For the light duty stuff I use the 3pt for, this setup works pretty good and I can switch implements fast and easy. I did have to replace that rod that connects the front hydraulic rockshaft to the rear rockshaft with a heavy duty, spring absorbing, version (from a 130 with a Fast Hitch.)
Pete
Hugh MacKay
07-05-2007 16:08:43
Mark: If you want a good cultivator hitch, take a serious look at factory 3 point hitches. Make note, how close lower links are at tractor in relation to implement. For good pulling of inground implements your lower links should be attached 4" in from final drive, and 6" ahead of the cultivator mount. If I were you, I'd use a cross member from side to side, weld 1/2" plates on the end to set cross member inline with and slightly below axles. You can use a large pin and pin the plates to the cultivator mount. Use a Ford or Fergie lower link 32" centers on balls.
I have been building these close to a year, believe me attaching direct to cultivator mount does not work, been there and done that. It will work for you mower, but not in ground tillage.
I do have photos and drawings.
mark
07-05-2007 21:43:32
 Re: SA 3 point in reply to Hugh MacKay, 07-05-2007 16:08:43
Thanks men for your replies. Hugh I highly value your input because of your long experience with the SA-140..et al. I'd love to see your drawings so I could fabricate a hitch.
Now, I have seen the aftermarket set ups and I think for what they cost, they ain't worth it. This endeavor is just a convenience thing. So far as cultivating goes...you can't fix what isn't broke, and in original form....you can't beat a SA for cultivation. I don't need the SA for plowing or grading or anything requiring high draft forces. I have been using my 65 horse tractor to mow the grass with and in some places, it's unhandy because of it's size. I had another SA with a belly mower and didn't like it at all. BUT, for narrow places....like edges next to the fences and so forth, I'd like to yoke the SA to the finish mower. I really didn't want to clutter the center undersides of the tractor with a hitch apparatus and restrict crop clearance...because this machine is primarily a cultivating tool. I have loaned it to a few neighbors and they all hate like hell to bring it back! To be 54 years old, it runs like a Timex.
