wiring lights on super c farmall
parisspringstom
07-05-2007 19:02:50
Hi I was hoping someone could tell me how to get the wires from the switch up thru the post to the lights. One wire goes up the post and a wire comes out of each side so they must splice in the post. I tried to hook wires to the old wire ends and pull the old wire out pulling the new wires thru but the old wire seems really stuck. It may be I need to take the light bar apart to get this light job finished. Thanks for any replies.
parisspringstom
07-06-2007 10:26:41
 Re: wiring lights on super c farmall in reply to parisspringstom, 07-05-2007 19:02:50
Thanks Guys
C-Man
07-06-2007 05:10:53
I just ran 2 wires from the switch. One for each light. I started with a small wire and was lucky enough to get it hooked with a small hook and then I pulled the larger wire through. I was able to put the small wire all the way through the "tube" and then I was able to use a small, but long, o-ring pick to pull it down the "post". Tie the wire you want to use on your lights to the small wire and it should pull around to corner of the "tube" and "post". I tried to take the set screws out of my Super C and they would not move. Good luck.
Andy Motteberg
07-05-2007 20:21:26
Here is a link to a good site for wiring diagrams. It will give you the info you need for wiring the lights.
