Farmall 400 Diesel Engine Determining Engine Number
Farmall_Rick
07-06-2007 08:09:29
I recently purchased a Farmall 400 diesel. The former owner drove the tractor to my house from his which was about 12 miles. When he arrived he shut the tractor off and we visited for awhile until he wife picked him up. The I drove the tractor around the yard a few times later that evening and then parked it. A day or so later I started degreasing and pressure washing the tractor so I could see where it was leaking, and then I would be able to fix those problems first. When I went to start the tractor up after the cleaning I had problems. First when I turned it over the tractor was switched over to diesel (Which I wouldn't think this would cause a problem with the tractor). I noticed antifreeze coming out of the exhuast pipe. I opened the drain valve on the carb and antifreeze came out (Which I thought was strange). Then I looked at the radiator and found that it was black in color. I owner told when he was using the tractor that he noticed that gas would drain out of the small fuel tank. I dismissed this as a leaking sediment shutoff valve which I could see that it was leaking. So after reading on this forum I believe I one of the following conditions 1. It was not shutdown properly after the long drive. 2. It may be a blown head gasket. 3. A cracked head. I called a parts dealer and he says that list to types of engine models for that tractor a (A251) or (A267) I am not sure how to determine which one I have. Number on my tractor block is D-26419389. Any help you guys can give would be appreciated.
John-Paul T
07-06-2007 10:56:12
 Re: Farmall 400 Diesel Engine Determining Engine Number in reply to Farmall_Rick, 07-06-2007 08:09:29
ya thats a IH engine not case. case would be after the merger in what 1985. Anyways I got google skills hahaha here ya go
Link
Seems to me its a D-264 (IH)
the other numbers on block should be date code, factory code and options included etc etc.
John-Paul
07-06-2007 10:59:20
 Re: Farmall 400 Diesel Engine Determining Engine Number in reply to John-Paul T, 07-06-2007 10:56:12
BTW, I think your on the right path. For coolant and fuel to mix its gotta be head or headgasket. Maybe even block but lets hope not. Best would be a bad gasket. Im not sure if it could cause it but check the cylinder sleeves too, for any cracks etc. Least they arent too expensive.
justin w
07-06-2007 10:27:33
your "parts dealer" doesn't have a clue. He is assuming that you have a Case 400 Diesel, not the IH Farmall 400 Diesel.
