super m cam
point3dave
07-06-2007 09:35:42
Hi Will a camshaft from a M work in a Super M? Tanks Dave K
point3dave
07-08-2007 06:02:22
 Re: super m cam in reply to point3dave, 07-06-2007 09:35:42
Thanks for your help on the M cam. I will check it out Dave k
D Slater
07-06-2007 13:58:15
Its best to look at what cam you have and what cam your buying. If you can find the # on it(usualy found on rough surface near front between machined parts) sometimes you can't read them or find. If you can find the # the ones that end in D suffix were used in M,SM,SMTA tractors. Ones that end with DA have the revised Valve timeing and were used in 400 and roughfly first 1/3 of 450 tractors. The cam was released for new 400 tractors but IH didn't always change at a certain time so some of the last SMTA could have ben equiped. ones ending with DB had the left hand thread change and used on rest of 450 tractors. When a cam change was made IH sold that cam for M tractors and whatever other tractors in series up until change was made for replacements after stock on hand run out. So later parts books printed will show same cam # for those tractors. Don't expect to find the same # on cam thats in parts book. On a 50 or 60 year old tractor don't take for granted what cam is in it,look for # or check specs. Cam gears may get mentioned also, they were improved at least twice with last improvment starting C264 engine # 155941 witch was in 400 tractors. So don't always go on tractor model for those parts either.
janicholson
07-06-2007 10:35:08
Use a 450 cam, they are the latest grind and very noticable power increase. JimN
Jim Ivens
07-06-2007 11:50:43
 Re: super m cam in reply to janicholson, 07-06-2007 10:35:08
Is there a difference in the cam in a 400 and a 450? if so can you still get them from IH ? My book shows same part number
BF8690
07-06-2007 09:43:50
It will but why would you? They are not ground the same and you might lose performance. Also, the SM cam has left hand thread locking nut where the M has a right hand threaded lock nut on the cam gear.
