230 Fasthitch
DozinHal
07-07-2007 05:24:16
I just bought a 230 with Fasthitch and two bottom plows. I cannot get the plows to go into the ground. The cylinder still has 2-3 inches left on it. Thanks
Dozinhal
07-07-2007 13:01:25
 Re: 230 Fasthitch in reply to DozinHal, 07-07-2007 05:24:16
I took pins out of a swaybar on the right side, but it didn't make any difference. Does the whole swaybar have to come off?
georgeky
07-07-2007 16:47:14
 Re: 230 Fasthitch in reply to Dozinhal, 07-07-2007 13:01:25
The pin I was talking about is underneath the hydraulic cylinder. It should have a little ring on it to pull it with. Just look at the bottom of it and you can see what I am talking about. It lets the hitch raise up on its on. The hand lever by your left leg is to adjust the amount of draft. This is IH's mechanical draft control. This time of year the ground may simply be to hard to get a plow in. I do suspect the pin removal will cure your trouble. Is your tractor spinning out before the plow gets in the ground good? If it doesn't work let us know and we might find a cure.
georgeky
07-07-2007 07:46:32
Look on the underside of the cylinder. There is a pin there that has to be removed before the plow will work. This makes the cylinder float instead of being rigid. With the pin in the tractor will lift the rear end up enough to cause it to spin out before the plow gets in the ground. May this late in the season the ground is to hard for the plow to go in.
