Order Farmall Cub Parts Online
Polarizing 6 v cub regulator
Geff
07-07-2007 06:26:21
does any one know the procedure to polarize a 6 volt regulator for a cub 1958?
Thanks
Janicholson
07-07-2007 06:37:15
 Re: Polarizing 6 v cub regulator in reply to Geff, 07-07-2007 06:26:21
Generators are polarized, (sorry) regulators are not. To polarize the Gen:
Place a jumper wire between a good ground, and the Smaller F terminal of the GEN.
Use another jumper to momentarily connect the battery terminal of the regulator to the Arm (bigger) terminal of the gen. This will produce a medium spark, and set the polarity of the field poles of the generator with magnetism. It actually magnetises the iron of the fields with the correct polarity, so the generator can self start when firstbeginning to get up to speed when started each time. JimN
Bob
07-07-2007 06:32:50
Regulators DO NOT need polarizing. What you are doing is polarizing (restoring the residual magnetic field in) the generator.
Momentarily jumper the BATT and ARM terminals at the regulator, which feeds battery current back into the generator, and polarizes it.
Geff
07-07-2007 06:47:13
 Re: Polarizing 6 v cub regulator in reply to Bob, 07-07-2007 06:32:50
the GEN on the rear of the regulator is the ARM terminal you ar talking about? Mine has 4 terminals L-BAT-FLD in front and GEN in back.
Thanks
Bob
07-07-2007 06:58:38
 Re: Polarizing 6 v cub regulator in reply to Geff, 07-07-2007 06:47:13
You've GOT it!
