706 PROBLEM
LF
07-07-2007 06:55:26
HAVE A706 WITH A310 BEEN GETTING HARD TO START THIS WINTER. WHEN I WAS CUTTING HAY IT WAS MISSING I CHANGED FUEL FILTERS THEY WAS DIRTY RUNS GOOD BUT WILL NOT START UNLESS YOU USE EITHER IT HAS 3300 HOURS DOES NOT SMOKE AND DOESNOT USEOIL WHAT COULD CAUSE IT TO NOT START IT SEEMS TO TURN OVER FASTER NOW ANY THOUGHTS!
the tractor vet
07-07-2007 07:59:53
 Re: 706 PROBLEM in reply to LF, 07-07-2007 06:55:26
First off are you using the start posision on the shutdown cable ???? if you are and still having a hard start condition it could be one of two things if the engine is in the shape that you clam . (1) you have low cranking fuel pressure in the injection pump casued by ware in the pump head . (2) your fuel injectors are not cracking at the propper breaking pressure . As for and easy cure NOT either the injectors and the pump will have to have them checked by a pump shop . Now the pump shop will not just check the pump out as they wil rebuild it before they even think of putting it on there stand . This is not the case with the injectors can be tested BEFORE being rebuilt if needed. While you have the injectors out this would be a good time to run a compression test on the engine but this will require special test equipment to do the compression test as a standard compression gauge won't do it.
