starter switch re: previous post
Carden
07-08-2007 15:35:07
Here is the picture from Ytmag parts site Link
It>Link does show it coming down at an angle so the foot pedal comes in contact correctly. This is listed as for an Super M or MV. This is the one>Link
listed>Link for an M which will not work on mine. My serial number shows it being an M but could it be a Super? I suppose it is more likely someone may have changed the hardware sometime.
Carden
07-09-2007 17:37:54
 Re: starter switch re: previous post in reply to Carden, 07-08-2007 15:35:07
Ok, thanks to all. I may need to check the reason for the discrepancy and figure out what will work best.
D Slater
07-08-2007 20:45:07
Reguardless of how switch is operated the same starting switch was used for M and stage one SM by IH. There were more than one part # sold but they interchange. Stage 1 SM LP tractors did use a different switch. Think IH started the foot lever to operate starting switch when hydraulic seat attachments showed up. If your tractor uses 3 bolts to mount starter its a stage 2 SM or diesel or the clutch housing is changed. On this site switch # 1925781 as pictured mounts direct to starter like stage 2 SM and some other models.
Tallperson
07-08-2007 20:22:15
My '53 SM has a handpull starter rod coming through the same plate as the choke rod and right above it.. The starter has a pivoting lever mounted above the starter push button... The rod attaches to this. Kinda handy in cold weather.. your hand is right at the choke when you pull the starter.. Tallperson
CNKS
07-08-2007 17:27:50
The second one, the one that does not work on yours fits perfectly on mine and is identical to the one it replaced. My M is a 1947. If yours is a Super it will have the prefix SM, not FBK. I do not have a Super. But, among other differences the choke rod attaches to the choke lever next to the block. On an M the choke rod attaches to the lever on the outside of the carb. Most of that type of parts are interchangeable.
Larry in Mo
07-08-2007 16:34:41
I can recall at least three different configurations of starter switch set ups on M's. Never spent enough time around a Super M to know what they had. On the M's one was a straight rod thru the steering post activated with your foot. One was a bell crank and bracket also foot operated. No. 3 was a switch mounted up on the steering post, hand operated. If yours isn't like any of these, someone has shadetreed it. Model for M's on data plate is FBK I think. On Supers, it is FSM. LE
glennster
07-08-2007 17:39:55
 Re: starter switch re: previous post in reply to Larry in Mo, 07-08-2007 16:34:41
here is the starter switch on my stage 1 super m. tractor is scattered all over the shop tho....
my 42 m has the rod that goes thru the steering post, and my 48 m has one similiar to this one. third party image
John M
07-08-2007 17:27:15
Your not the first one to mention the switch on the upper part of thr post like the Hs, but I have never seen it there on an M. I have seen and have both the short rod and tye foot type acuaotr
