Farmall F-20- odd ring for spark plugs
Andy Motteberg
07-09-2007 17:37:36
Hi,
My Dad bought a 1936 Farmall F-20. The engine is stuck so I removed the plugs to put some penetrating oil in the cylinders. When I removed the plugs, they were smaller Autolite spark plugs. The F-20 usually has large spark plugs, but there is some part that is threaded into the original sized spark plug holes in the cylinder head so the smaller plug will fit. What are they for? Are they hard to find? I've never seen anything like them before. If you can't understand my post, I can take a photo if that would help.
Thanks,
Andy.
jamesinOk
07-09-2007 19:02:57
 Re: Farmall F-20- odd ring for spark plugs in reply to Andy Motteberg, 07-09-2007 17:37:36
Andy: you used to be able to purchase extenders that fit the spark plug hole. the extender had a small round hole. theory was that if a motor was fouling plugs, it would be harder for oil to reach plugs. Champion used to make these extenders. James
Andy Motteberg
07-09-2007 19:45:33
 Re: Farmall F-20- odd ring for spark plugs in reply to jamesinOk, 07-09-2007 19:02:57
Thanks for the info.
rls_ia
07-09-2007 17:43:13
These are an adapter so newer plugs can be used. I have seen them advertised but I can't recall the company's name.
Hope this helps you some, Bob
F-Dean
07-10-2007 05:59:26
 Re: Farmall F-20- odd ring for spark plugs in reply to rls_ia, 07-09-2007 17:43:13
Look in Red Power. They advertise thera all the time.
Andy Motteberg
07-10-2007 17:18:10
 Re: Farmall F-20- odd ring for spark plugs in reply to F-Dean, 07-10-2007 05:59:26
Where can I get to redpower? (website).
Andy Motteberg
07-09-2007 18:37:24
Thanks.
