140 6 volt generator not charging
Tab
07-09-2007 18:32:36
On my old 140, I don't think it's charging. Still on the original positive-ground 6 volt system. Looks like somebody recently replaced the voltage regulator, and the meter looks fairly new, also. When running, the meter reads negative. When not running, and you pull the ignition switch out, it immediately goes neg.(from the neutral mark)-- so I think the meter is working. Battery is good, also. Everything looks very good, visually. Any short-cut jdeas for checking? I'm not very good with wiring.....Thanks for any ideas.....Tab
Tab
07-11-2007 13:11:24
 Re: 140 6 volt generator not charging in reply to Tab, 07-09-2007 18:32:36
Well, I took the generator to my old, retired mechanic, and he took it apart and noted that one brush was stuck, not making contact. He fixed it, hooked it to a battery charger, and it took off like a motor. We thought the problem was solved. I put it back on the tractor, and it STILL won't charge. It's funny how you can have an old, rusty, crappy-looking tractor that runs and is mechanically flawless, and then you can buy a nice-looking, one-owner, well- maintained "pretty" tractor that gives nothing but trouble.I guess "lemons" come for the farm, too. I'm sure I will get it right, sometime.
Erik Dekeyser
07-09-2007 19:26:46
Well the first thing i would do is take the generator to a place that can check it out to make sure its working. And if its working then you will have to look at the regulator and wirring. Good luck ...
Bob M
07-09-2007 19:23:10
Tab - Punch below for a generator troubleshooting flow chart. Follow it through step by step - it should help you isolate the problem.
Tab
07-10-2007 04:44:16
 Re: 140 6 volt generator not charging in reply to Bob M, 07-09-2007 19:23:10
Thank you all for the help. I think the trouble-shooting chart that I just printed out is going to be a blessing..Thanks again!!!.....Tab
City-Boy McCoy
07-09-2007 19:19:40
I would start by polarizing the generator per the procedure in the operator's manual. If it works, and it well might, it is the quick and correct fix for your problem. mike durhan
