What is an I-6?
Poooch
07-10-2007 11:28:25
I recently bought a tractor that is an International. I thought that it was a W-6 but the ID says it is an I-6. Can someone give me some info on how to properly ID this tractor and maybe find out what year it is. I found it in a field and the person who sold it to me said that the engine was frozen. I took it home, put a rotor in the mag, installed the carb after soaking it in carb cleaner and it fired right up. I would like to restore it. It can go to work right now. If anyone can help i would appreciate it. Thanks
Andy Motteberg
07-10-2007 16:49:44
 Re: What is an I-6? in reply to Poooch, 07-10-2007 11:28:25
Industrial 6
Haas
07-10-2007 14:08:01
I have an I-6. Some differences between it and the W-6. Narrower rear wheel tread, different transmission gears (high speed 4th and low speed 1st). Third gear is about the same as 4th on a normal M transmission. It also may have solid cast front wheel hubs, or it may have the normal spoke type cast hubs. Rear hubs will be solid cast hubs. They are very heavy, about 3 inchis thick where the rim mounts to the hubs and thicker at the center. Various hubs and tires were available, but most I-6's came with 24 or 26 inch size tires on the rear I believe. Mine has 24 inch rears. (14.9x24 as I recall which would have been the old 13X24 size). I think most W-6 tractors had 30 inch tires on the back. Also there were other options such as hydraulic brakes and a brake on the clutch to stop the transmission when the clutch was disengaged for easier shifting. The drawbar arrangement was also different than the W-6, the normal one being for a pintle hook ring. There may be other variations. Mine has a home made drawbar, as it was used as a farm tractor and the one that came on it was not suitable for farm implements.
Wardner
07-10-2007 12:18:53
Wheels, tires, and drawbar will be different. It's possible that the fenders and seat may be different. I dunno. The front axle may be heavier to accommodate an industrial loader. Get the parts books for both the I-6 and W-6 and then you will know. It is possible that both tractors use the same book.
Wardner
07-10-2007 12:18:05
georgeky
07-10-2007 11:34:18
It is an industrial version of the W-6. You can click on serial numbers to the left of your screen and find the model year. That is if you know the serial number.
