farmall 856 weight??
t.r.y.
07-10-2007 11:59:38
Hello I have a 856 diesel widefront 3pt 18.438 with fluid anybody know around about weight I'm figuring 12000?? thanks
Goode
07-10-2007 17:20:35
 Re: farmall 856 weight?? in reply to t.r.y., 07-10-2007 11:59:38
If I remember right, the book on an 856 I used to own said dry weight was 8,800+ pounds. That seems to disagree with the Nebraska test. But, with 18.4x38 tires with fluid, all other fluids in the tractor, plus a heavy cab with built in roll bar, I ball-parked it at about 13,000.
the tractor vet
07-10-2007 13:33:00
Better set your sights a bit higher as my 806 narrow ft. with loaded 18.4x34's fast hitch flat tops bumps the scales at 11800 . The figures in the book are SHIPPING weights that means no fluids no Acc.
Retcol
07-10-2007 12:46:12
Based on the Nebraska test the 856 bare weight was 10290 and it was augmented with 850 lbs of liquid in each tire which brought it up to about 12000 lbs.
georgeky
07-10-2007 12:01:30
You can check Tractor data.com. Some of their info is questionable though.
