m puffs smoke out what iis it.
james in mo
07-10-2007 13:58:47
at start up my m will puff all white smoke out. and somtimes while your throtling up. someone told me this could be antifrezze but notice no depleation in radater fluid height. anybody got ideas.
Janicholson
07-10-2007 15:58:51
 Re: m puffs smoke out what iis it. in reply to james in mo, 07-10-2007 13:58:47
If the smoke drifts away in a cloud it could be oil from worn guides. Especially if the smoke is also present when going down a hill in high gear and idling it down (causes high vacuum and pulls oil through intake guides)
If it smells sweet it might be antifeeze. After sitting over night pull all the plugs and have someone crank it (without the ignition on) If water/antifreeze comes out a cylinder, it is a leak. Head gasket, or cracked Head most likely.
Best of luck, JimN
old
07-10-2007 14:09:43
Could be coolant but it could also be from condensation and if you have been getting any rain lately you could also be getting a little water in the cylinders/manifold.
