Order Farmall Cub Parts Online
Cub 154 ignition switch question
888
07-11-2007 07:16:43
Hey all;
I redid some dash wiring on the 154 this weekend (the charging inidcator was bypassed) and when I tried to start, there was no response at all. I have good voltage at the battery, the rain started and I have not been able to go back out and check more. I suspect that the physical ignition switch (with key) is not working to provide voltage downstream to the starting switch, here's why. There was a loose ring terminal connection on one of the switch studs and when I tightened the nut down to secure the connection, the complete electrical (brown) half of the switch spun around inside the silver outer housing. I assume that this is not a good thing and I have broken whatever connections exist between the key and the electrical terminals. Anyone else ever had this happen?
thanks
Janicholson
07-11-2007 11:50:16
 Re: Cub 154 ignition switch question in reply to 888, 07-11-2007 07:16:43
Your assessment is likely correct. (it is a potential fire strter as well) Take it apart enough to get at it and repair, JimN
888
07-11-2007 17:45:37
 Re: Cub 154 ignition (now wiring) switch question in reply to Janicholson, 07-11-2007 11:50:16
Thanks for the input. I swapped it out tonight and while examining the old switch and the replacement switch, I noticed a difference. The old switch had BAT IGN ACC molded on the 3 lower terminals and ST with an arrow on the central "tower" terminal (like a coil terminal on a distributor). The new switch only had the BAT IGN and ACC marked, no ST. The schematic does not mention an ACC position but the key can go to the left to what would be an ACC position on an older car ignition. I was thinking this may be a "universal" ignition switch with an ACC option. When I got the tractor, the wiring was a mess but I clearly recall there was no wiring to the central tower terminal. Is that central terminal the starter terminal? I wired it that way and still no sign of life. However, when I got the tractor the charging meter was bypassed, I may need to replace that to get current flow to the starter switch, I assume the current must flow through the charging indicator to get to the starter switch? For right now, everything is wired as per the schematic and there is no sign of life. Thanks for any comments or advice.
Joe
Janicholson
07-13-2007 10:01:29
 Re: Cub 154 ignition (now wiring) switch question in reply to 888, 07-11-2007 17:45:37
Sorry for the delayed response.
If it has no ST terminal, it probably does not have a spring loaded start position as the key turns! thus it is either the wrong switch, or the unit had a push button starter switch to make the starter solenoid operate. Battery terminal should be attached to (if it were mine) a 35 amp inline fuse holder and fuse. then to the hot side (battery side) of the soleniod. The Ignition terminal should go to the coil (or ballast resistor if so equipped). The Acc terminal is not used unless you have a radio or other device you need to operate while the ign is off. Leave it empty. Without a starter terminal a starter button (momentary contact weatherproof push button) should be connected to the bat terminal of the key, and the start (S) terminal of the solenoid.
If it has an alternator, the indicator light should be wired to the Ign terminal on the key (I think) JimN
888
07-13-2007 11:27:25
 Re: Cub 154 ignition (now wiring) switch question in reply to Janicholson, 07-13-2007 10:01:29
Thanks for the reply, Jim. The key switch (old and new) does have a spring loaded return from start to run. I think the problem is that the later molds don't have the ST mark, they must assume that we know the unmarked one is the starter. Other that this missing ST molded on the center post, they are identical.
I have a generator with a charge indicator rather than an alternator. The charge indicator was bypassed when I got it by the PO wiring the red leads in and out of the charge indicator together along with the red lead from the 8 pin connector to the BAT terminal. I am told it ran like this for a few years and last fall until it wouldn't start this year. It was thought mice got into the wiring.
I wired it all back to the way it's shown on the schematic and I've traced most everything down and tightened/cleaned all contacts. I'm missing the inline fuse and holder between the light and dark green leads off of the 8 pin connector. I'll need to replace that, I guess. Can i use a modern standard plastic bladed fuse and holder? That's what I was planning on but I can use a glass barrel.
I saw a starter safety switch on the schematic and finally traced it down last night under the rear fender where it senses the position of the PTO lever. There are two wires that are part of the starting circuit, orange and orange/black. Both were off of the switch. One of the wires was broken off back by the PTO with half laying on the PTO and the broken end was riding on the metal body. I'll need to rewire that too. I wonder if this is what shut it down. Does it need this contact to start? No indication if it's normally open or normally closed.
If all this doesn't work, I'll need to find a new charge indicator. I did notice that the insulating laminate on the back of the charging indicator was cracked by the screw terminal and ready to fall off so i guess I'll install something to insulate that before springing for another one.
Good thing I didn't pay much for this, I'm getting a lot of time in it. thanks for the help.
Janicholson
07-14-2007 10:50:09
 Re: Cub 154 ignition (now wiring) switch question in reply to 888, 07-13-2007 11:27:25
Make sure there is power (test light) comming from the ST terminal (with no ST marked on it) when the key is in this position.
The neutral safety switch is normally closed and in series with the starter solenoid to the start terminal mentioned above. If the interlock safety sw is ruined, the two wires going to it can be wired together (realize it will start with the PTO running, as all tractors before our litigeous society became aware of the nature of idiot operators) I do nt have this tractor, nor have I been around one or looked at a book, My diagnosis is purely experience on mobile technology from 1955 till now, (born in '49) JimN
