CNH paint with hardener
BOBM25
07-11-2007 08:50:28
What kind of hardener can be used with the paint from the CaseIH store? The silver/gray paint for the wheels in particular. I used some of this paint to touch up some rims with a brush and found that normal paint thinner would not clean the brush out, I had to use lacquer thinner. Can I use the same hardener as I put in Dupont Centauri 7410, or will there be some kind of reaction? I've never used the Case paint before, but I know some guys have gotten good results using it with hardener, so I want to try it on my rims. Thanks
Fancy Farm
07-11-2007 19:41:30
 Re: CNH paint with hardener in reply to BOBM25, 07-11-2007 08:50:28
Need to check real close before you put hardner in the silver CNH rim paint.
May not be compatable.
44 massey
07-11-2007 14:38:38
I have painted several farmalls with the CNH (2150 red) paint and have always used martin senior 15117 hardener and havent had any problems,,,,, ,,,,, ,,worked great
unioncreek
07-11-2007 11:58:06
Check with your Case/IH dealer some carry the hardener and some don't. You can also go to JD since their paint is made by the same company and they can order the hardener, I believe it's made by Velspar.
Bobg
GeneMO
07-11-2007 15:13:05
 Re: CNH paint with hardener in reply to unioncreek, 07-11-2007 11:58:06
Put paint on an IH that you buy from John Deere?
Wash your mouth (actually fingertips) out (off) with soap !!!!
Just Kiddin" My son is an Account Manager, Ag National Sales for Deere.
Gene
