1951 Farmall-H 3-point hitch/backhoe advice
Ron Olsberg
07-11-2007 17:26:53
I have purchased a 1951 Farmall Model-H tractor that currently has the wide front axle and a front end loader. I am considering the purchase of this backhoe model KPX LW-6 >Link
to>Link attach to this 3-point hitch>Link
Has>Link anyone attached the model KPX LW-6 backhoe to the 1951 Farmall Model-H or similar model tractor?
Anyone used the Saginawcountytractor 3-point hitch? used this 3-point hitch with the KPX LW-6 backhoe?
I am a new owner so any advice would be appreciated regarding the attachment of a backhoe to the Farmall Model-H via a 3-point hitch.
BTW.. This tractor has a fairly powerful rear PTO attached hydraulic pump. Will I have any clearance problems?
Nat 2
07-12-2007 06:59:41
 Re: 1951 Farmall-H 3-point hitch/backhoe advice in reply to Ron Olsberg, 07-11-2007 17:26:53
Oooh, that's a pretty specific combination. I doubt if you're going to find anyone with specific experience with that specific pairing.
However, there are many people with good things to say about the Saginaw hitch, and just how much it can carry. Make sure you get the version with two hydraulic cylinders.
The backhoe only weighs about 1000lbs, so it'll be no problem for the lift or the rear end of the tractor. I would imagine that since the 3pt arms hang way out behind the tractor, more so than a normal 3pt, the PTO pump will have plenty of clearance.
