It did not fit!
Tom Windsor
07-12-2007 19:17:17
While rebuilding a carb for my H, I sorted through the box where I had several bodies and picked out the best one and then rebuilt it. The new manifold came in and I prepared it and installed it. So, it was time to put the carb on. I did, and got the govenor thingie properly inserted into the carb. And, then, low and behold, the pipe or whatever it is called, that runs from the govenor body to the carb did not match up at the carb. The holes were different and it would not line up. So now what...back to the junk box and found another govenor, removed the item from it, and after an hour, had the one on the tractor removed and the other one installed. I never dreamed that there would be a variation in this attachment.
TW
georgeky
07-12-2007 20:34:47
 Re: It did not fit! in reply to Tom Windsor, 07-12-2007 19:17:17
I took a Zenith carb off a Super C and tried to put it on another, and it wouldn't fit. I wondered what in the world is going on. I measured and the manifold and that carb had 1/8 of difference in the mounting holes. I then remembered the carb was mounted with smaller bolts with nuts on them. I checked the part number and turned out that carb was for a Allis Chalmers and had been rigged to work on the Super C. I don't have an Allis, but have a carb for one.
