Super C PTO Interchange
Wayne Mo
07-12-2007 20:36:59
I want to switch the whole PTO unit between my C and my Super C tractors. Is there any problems doing this before I tear in to it and find there is some sort of difference? It looks like they will interchange by unbolting the PTO unit and sliding it off the rear end coupling. Any last minute advice from someone who has removed these units before?
Jim Becker
07-13-2007 08:17:14
 Re: Super C PTO Interchange in reply to Wayne Mo, 07-12-2007 20:36:59
There was a shaft difference from A to Super A. Don't know about the C to Super C. Without looking, I would guess C and Super C to both be similar to Super A (although not interchangable).
MN Scott
07-13-2007 06:29:14
The C and Super C units are the same. I have a C unit in my Super C and it works fine. The shaft differances are in the H.
gene bender
07-13-2007 02:45:53
Dont bet on the swap as there were two types of couplers that enguages the pto and therefore the main shaft in the tranny will either have an inverted spline or it could have the two bladed output. You wont know intil you have removed them. The tubes should interchange but check all the stuff before re-assembling.
georgeky
07-12-2007 20:43:09
Wayne, there the same unit. Should be no problem at all.
