Loud , hard starting SM
Keith L
07-13-2007 18:36:06
I've got a SM that starts hard and is very loud when running. Also, one plug always gets oil fouled after 10 hours or so of run time. When I put all these together, it makes me think I have a valve that's not closing or a broken valve spring or something. Any thoughts?
glennster
07-13-2007 19:08:02
 Re: Loud , hard starting SM in reply to Keith L, 07-13-2007 18:36:06
run a compression test on all cylinders. then add a couple squirts of oil to each cylinder and re run test. if the reading are low and dont come up, suspect valve problems. could be they just need adjusting, but the oil burning cylinder may have a worn guide or bad seal. pull the valve cover and inspect the valve train too.
