Rebuild Tachometer
M. Paulus
07-15-2007 19:02:30
Does anyone know where I could get the tachometer on my Farmall 450 rebuilt?
flying belgian
07-15-2007 19:59:53
 Re: Rebuild Tachometer in reply to M. Paulus, 07-15-2007 19:02:30
take it apart and build up the worn tooth(teeth) on the plastic drive gear with epoxy glue. then file the teeth back in the gear. I have done this with two and one has been working for over 2000 hrs. and the other for 800.
Wardner
07-15-2007 19:22:08
This is where the archives come in handy. Bates in Indiana has a good reputation for rebuilding tachs. However, they send them out to shop several states away. Someone posted the name of this shop several months ago. Presumedly, they will be cheaper than Bates but you will get the same quality.
Wardner
07-15-2007 20:00:56
 Re: Rebuild Tachometer in reply to Wardner, 07-15-2007 19:22:08
Gonna save you the trouble of using the archives. Call Abbott Tachs @ 800 643 5973
