Farmall 300 Lights
Matt Weltz
07-15-2007 19:10:58
Well the 300 that I am restoring is almost finished. Got all the new wiring run today. I need to get tnew lights for it though and am not sure if I should get 6-volt or 12-volt. It is a 6-volt system but has a GM style resistor bar so a 12-volt battery can be used. I am thinking I need 12-volt lights as it had the original 6-volt lights on it still and none of them work. Anybody know what voltage of lights I should order?
Janicholson
07-16-2007 13:09:54
 Re: Farmall 300 Lights in reply to Matt Weltz, 07-15-2007 19:10:58
The way you have described the tractor, it may not charge the battery. I recommend a Hitachi alternator they are smaller and very robust. If you want to there are 12v delco generators that are direct replacements for the 6v. (you would be using it positive ground, and with a new regulator. The resistor (on the ignition) is needed unless you use a coil rated for no external resistor. Bob M wiring diagrams (search this site) answer a lot of questions) JimN
Al -VA
07-16-2007 06:47:06
By all means go 12 volt including lights. I did that with my super H and am very happy. Much easier to find 12 volt batteries and usually cheaper.
georgeky
07-15-2007 19:13:31
If you are using a 12 volt battery, then you need 12 volt lights, they are a lot brighter too.
Matt Weltz
07-15-2007 19:22:11
 Re: Farmall 300 Lights in reply to georgeky, 07-15-2007 19:13:31
That is what I thought. Just wanted to make sure. Thank you!
