460 troubles
smdv806
07-16-2007 13:24:07
I put new points in the 460 and now it won't hardly start without using the choke for a while. It seems to run well at the higher rpms, but if you idle it down it dies. What is the problem? It seems to be throwing fire back through the carb also. I have it gapped at 25.
ChrisAS
07-16-2007 13:26:35
 Re: 460 troubles in reply to smdv806, 07-16-2007 13:24:07
gap should be .020 so timing is somw late.
RustyFarmall
07-16-2007 13:52:41
 Re: 460 troubles in reply to ChrisAS, 07-16-2007 13:26:35
Yep, .020". it does make a differance.
smdv806
07-16-2007 16:56:15
 Re: 460 troubles in reply to RustyFarmall, 07-16-2007 13:52:41
what are the plugs supposed to be gapped to?
RustyFarmall
07-16-2007 17:19:16
 Re: 460 troubles in reply to smdv806, 07-16-2007 16:56:15
.025"
