tractor rim measurements
bil b va
07-16-2007 13:33:48
how is the width of a tractor rim measured ? from the outside to outside or inside where the tread rests ?
CNKS
07-16-2007 18:32:26
 Re: tractor rim measurements in reply to bil b va, 07-16-2007 13:33:48
If they are IH rims, and you have the tires off, you may find the width stamped on the inside. Otherwise do as Rusty says, you can't measure properly with the tires mounted.
RustyFarmall
07-16-2007 13:51:29
Measure from the inside of the rim bead, to the inside of the opposite rim bead. Your measurement should come up to almost the exact inch.
