u joint on hand crank
bgrimes
07-16-2007 13:53:12
The u joint on my F12 Farmall hand crank has broken. The pin with a hole through it broke due to the thin metal and wear. What are my option to repair this ? Are parts available or will I have to make this pin?
Bob Kerr
07-16-2007 18:21:32
 Re: u joint on hand crank in reply to bgrimes, 07-16-2007 13:53:12
I would just make one, Get some round stock at an auto parts store or a machine shop if you have one near. May have to "stake" it in place. I have also used a bolt on the 10-20 for the crank handle end. I have seen a couple that had roll pins used.
