Farmall H and Farmall Super A implements
Chudimac
07-17-2007 05:25:11
Just found a wonderful deal on a 2-bottom plow for a Farmall Super A. I'm assuming a Super A implement will not fit an H correct?
georgeky
07-17-2007 08:14:27
 Re: Farmall H and Farmall Super A implements in reply to Chudimac, 07-17-2007 05:25:11
You need to think about a number 8 Little Genius plow for your H. They are trailing plows that can be pulled by any tractor. They were available from 1 to 4 bottoms and are as good as you can get. Your tractor is well suited for a 2X14 inch bottoms. There are lots of these plows around.
CNKS
07-17-2007 05:30:05
Attaching points are not even close to being the same. Simple answer is that you are correct.
Chudimac
07-17-2007 05:38:11
 Re: Farmall H and Farmall Super A implements in reply to CNKS, 07-17-2007 05:30:05
Too bad... thanks!
If anyone in the NC Triangle area wants a 2-bottom, Super A plow for a good deal, let me know.
