H battery group
JJ
07-18-2007 07:12:59
I need to pick up a new 6 volt battery for my H. Anybody know what size group it takes? Forgot to look before I left the house this morning. Thanks
Nat 2
07-18-2007 09:28:20
 Re: H battery group in reply to JJ, 07-18-2007 07:12:59
Most auto parts stores only stock one size of 6 Volt battery, a Group 1. That'll probably be all you can get today.
JJ
07-18-2007 07:44:58
Thanks for the info.
John T
07-18-2007 07:39:29
JJ I dont have those battery group sizes, buttttt ttttt t on 6 volt applications, especially if you need to start at extreme cold temps, I advise the absolute biggest, heaviest, highest CCA or Amp/Hr battery that you can physically stuff into the battery box/compartment and the use of 00 gauge battery n Starter n ground cables..... ...
Id just measure the battery box/compartment then go to the battery shop n get the biggest n heaviest highest rated one that will fit in the box
John T
JOHN IN PENNSYLVANIA
07-18-2007 07:36:02
THE GROUP CODE IS "1" I WORK AT NAPA AND THE BATTERY YOU NEED IS PART NUMBER 7244
