SH Generator
GordoSD
07-18-2007 15:00:28
What is the rated max output of the generator on a 54 Super H, and at what rpm does this firsst occur?
Gordo
Janicholson
07-18-2007 22:09:19
 Re: SH Generator in reply to GordoSD, 07-18-2007 15:00:28
With the engine at High Idle (wide open unloaded), the generator is spinning maybe 60% faster (a guess from looking at the pulleys) It will generate about 15 to 20 amps on a good day when cool, a bit less if it is hot. The amount is only mportant if you are using it up with an accessory (extra lights). The real issue is charging volts, with a fully charged good battery, the charging volts should be 7.1 to 7.3 volts. (14.2 to 14.6 for 12v battery) If the voltage is correct, the amps will take care of themselves. JimN
CENTAUR
07-18-2007 16:01:49
Could you post the BRAND-MODEL#&NUMBER of your generator if it is still there. CENTAUR
GordoSD
07-18-2007 17:40:53
 Re: SH Generator in reply to CENTAUR, 07-18-2007 16:01:49
It's a Delco 1100501-3G15
Gordo
