706 CLUTCH PROBLEMS-PLEASE HELP??
BIG RED 1
07-19-2007 08:13:34
706 GAS WIDE FRONT.AFTER MOWING FIELD,PULLING ON TO ROAD SHIFTING FROM 2ND TO 3RD,AND 3RD TO FOURTH THE TRACTOR WILL HESITATE FOR 2-3 SECONDS AND GRAB THE CLUTCH OR GEAR THEN PULL THE FRONT END OFF THE GROUND AND THEN DO AS IT SHOULD(SOME TIMES 2-3 TIMES) THE CLUTCH SEEMS TO BE THE SORE SPOT.
THE TA IS IN HIGH AND THE OWNER NEVER USES IT.
THE PTO IS NOT ENGAGED EITHER WHEN THIS HAPPENS.
AND IDEAS? AS ALWAYS THANKS IN ADVANCE
RANDY
the tractor vet
07-19-2007 15:33:58
 Re: 706 CLUTCH PROBLEMS-PLEASE HELP?? in reply to BIG RED 1, 07-19-2007 08:13:34
After thinking about it for a while check the dump valve on the back side of the MCV for any sticking or binding that is about all unless ya are about out of hyd oil.
Kevin Meier
07-19-2007 13:52:01
i found some troubleshooting stuff on a web site
JUMPY ENGAGEMENT OR POOR RELEASE. A. DISC BENT (TRACTOR FORCED TOGETHER OR DISC DROPPED). A. GRIND FLYWHEEL TO CORRECT SPECIFICATION. B. DISC DISTORTED FROM HEAT (EXTREME SLIPPAGE). B. B. REPLACE DISC. C. PPA NOT ADJUSTED CORRECTLY. C. REPLACE PPA OR CORRECT ADJUSTMENT SPECIFICATION. D. FLYWHEEL NOT GROUND TO CRANK D. GRIND FLYWHEEL TO CORRECT SPECIFICATION. E. 86 SERIES CAB MOUNT WORN EXCESSIVELY. E. REPLACE CAB MOUNTS. F. F. RELEASE LEVER CRACKED OR BROKEN. F. REPLACE PPA OR RELEASE LEVERS.
G. PPA PIVOT BLOCK LOOSE. G. REPLACE PPA. H. DISC BINDING ON INPUT SHAFT. H. CLEAN DIRT AND GRIME FROM SPLINES. IF SPLINES WORN, REPLACE DISC. I. PPA NOT FLAT IN FLYWHEEL. I. INSPECT FLYWHEEL TO INSURE PPA MOUNTING SURFACE IS NOT TAPERED ALLOWING PPA TO BE DRAWN DOWN UNEVENLY. J. FAULTY PILOT BEARING. J. REPLACE PILOT BEARING.
the tractor vet
07-19-2007 10:09:32
Now thats a new one on me , is the oil lite comming on and stayen on for a few seconds after ya let the clutch out???? Have you checked the hyd. oil level lateley . with out being there and realy checking it out myself we are shooten blanks here.
RustyFarmall
07-19-2007 09:33:43
Might be the clutch, but it might be a tooth or two missing from a bull gear.
