older Farmall's,
kirk in ks,
07-19-2007 16:33:18
I was alway's wondering why the farmall F-20 and 30 and that series all sounded real nice and throaty, But the later letter series sounded smooth but not the throatyness of the earlier one's,
the m,s and 6's had more size but didnt sound as nice as the oldermone's and that's why i liked the regular, 20 30,12,14,s,
was it the RPM'S OF THE OLDER ONE'S,
or was it the timing and different design of the engine,
Or a combination of thing's,
Kirk,
JohnG(TX)
07-20-2007 11:12:56
 Re: older Farmall's, in reply to kirk in ks,, 07-19-2007 16:33:18
I have found the same thing. I have a 1936 F-20 with the iron exhaust elbow, and an M with a 2' straight pipe. With both at high speed idle, the F-20 will deafen you while the M just purrs. The M has twice the horsepower and more cubes, but is considerably quieter.
Nat 2
07-20-2007 05:37:10
One thing, the F series didn't come with mufflers... An open pipe sounds a lot different, "throatier" as you put it, that's for sure.
James Williams
07-19-2007 22:34:25
Kirk,during last years plow day I was pulling a drag with my F12 and a fellow was beside me was plowing with his JDA and he hollared to me and said that my tractor sounded good.and I complmented him on the sound of his tractor.What music a 2 cylinder and a long stroke 4 cylinder
jimmy williams
flying belgian
07-19-2007 19:09:11
sometimes the fan noise can override the exhaust noise. I like the sound of a H Farmall better then a SC Case because you don't hear the fan as much on the H.
Bob Kerr
07-19-2007 18:42:10
Valve timing and size has a lot to do with sound as does compression ratio and stroke and overall CID. Also the size of the exhaust pipe makes a difference. I would say it was the combo in this case. I like the sound of the old ones myself!
kirk in ks,
07-19-2007 19:02:32
 Re: older Farmall's, in reply to Bob Kerr, 07-19-2007 18:42:10
Hi Bob,
I just got you letter, and i really agree with you, as the older F-20's have a sound all their own,
I like it even better than Johnny Popper's,
Im salvating for a 35 grey one with red wheel's,
probably when I dont look for one ,
there Itll be in front of me,
Kirk,
ScottyHOMEy
07-19-2007 18:05:19
Not sure on that, Kirk. I don't know the 20 or 30, but do know how that a friend's F-14 has a different sound from my BN and SuperC.
I don't know tha the engines from the F-14 to the 113 and 123 were all that different in basic design and if I had to venture a guess, it might have to do with the fan and/or the tinwork. I hadn't actually had any distance on hearing my tractors running hard until I let a friend (who kindly lent me the garage space for a coupla weeks to paint the BN) take it up the road. As he got away a little bit, I heard a sound I hadn't heard in years -- I'd forgotten about bein' at the house and hearing that tractor running out in the fields. What you hear is not the exhaust but the fan. So I'm thinkin' maybe the fan might be driving more air of the letter series, or maybe is just resonates more with the shroud and grill than it did on the F-x's.
A thought, anyway.
