1948 Farmall C
shane Hoefs
07-20-2007 07:12:41
I recently bought a Farmall C with a belly mower when using the tractor after about an hour it starts to miss then eventually stall. After the tractor has sat for an hour or 2 it starts right back up and runs great then it does it all over again. Please Advise Thanks
gdo2444
07-20-2007 15:45:55
 Re: 1948 Farmall C in reply to shane Hoefs, 07-20-2007 07:12:41
I agree on the coil, but if that doesn't work, replace the "condenser", or capacitor, in the distributor. They can cause some really strange things.
Andy Motteberg
07-20-2007 12:17:05
Sounds like bad plugs or ignition coil.
NawlensGator
07-20-2007 09:48:13
Feel the coil when it quits. I bet it'll be hot as a firecracker.
georgeky
07-20-2007 07:26:32
Yep, bad coil more than likely.
ScottyHOMEy
07-20-2007 07:21:42
Sounds like a classic case of a bad ignition coil.
El Toro
07-20-2007 07:20:50
You probably have a bad coil. When it quits running you need to check for fire from your coil wire by holding holding it near a good ground while someone makes an attempt to start the tractor. You need to do the ASAP. before the coil has a chance to cool. Hal
